For the second time in three days, my HC3 showed a message "Serious problem detected. System was restarted".
Any idea what causes this?
(maybe contact Fibaro support)
That is actually good idea, we should check the logs to determine what is happening :)
    I have opened a support case. Actually, more than one, because I have several problems after the migration from HC2 to HC3.
    I have the same issue.
    The support asked me to send them the logs right after the restart ... only, not easy because the crash occurs at any time.
    Anyway, all I can say is that the crash took place between 10 and 13 days after the last reboot.
    Hardware issue ?
    I'm also seeing this happening. No idea why tho.
    Same here, starting about 2 months ago, a freeze eache 2 weeks. I the last 2 weeks, i have to manually power off and on, about every 3-4 days ....
    in the log appears: "Serious problem detected. System was restarted."
    SW V. 5.090.17
    It happens almost every day now.
    I have opened a support ticket and they are looking at the logs, so I hope they find the cause.
    Thank you for your feedback, because I think it will interest us all to know where it comes from !
    we are working on this problem
    Thank you so much
    For my part, I had the same problem last night at 4:32 am.
    It is therefore difficult to export the logs at this time.
    Thanks for your help.
    Have been running 5.091.41 (beta) for a while and today noticed "Serious problem detected. System was restarted" was logged 3 hours ago, that would be at around and about 03:00 - 04:00.
    I bit late to notify support or gather logs I guess?
    +1
    happened two times since installed 5.091.41 (beta)
    Same here, just sent an email to support.
    Also it's 8 months that I continue to receive the message System migration complete ... I already cancelled it I don't know how many times ...
    Same here, SW 5.0.90.17.
    Is it possible to log the problem and the admin user can read the log by him self, why system reboot....!
    This notification issue is resolved in current beta :)
    Same thing here, since February, with only a few devices and a few scenes (I stopped the migration from HC2 because of this issue).
    I send myself an email every time my HC3 reboots.  I read that Fibaro's support needs the logs produced immediately after the crash: how many time do I have to collect them?
    TIA.
    David
    Few hours, but as fast as possible.
    We are working on a solution and hoping that this will be resolved soon.
    For me the message 'Serious problem detected' and restarted only happened once in the middle of the night and impossible to know why !, my HC3 has version 5.090.17 and for the moment 63 devices.
