Fibaro as a primary controler but with other RTI zwave gateway as a secondary controler
hi I am trying to add one RTI z-wave secondary controler called  RTI
  inside fibaro interface of my HC2 i start the process using the normal add device option, like a fgs-223 or other, the process start work, my hc2 can find the rti zwave gateway, and after some time, show-me a message about "the process was failed"
Why?
can you help me whit the problem?  what do you need? some logs errors ? let me know!
Why?
i don't have a hc2, but i think you have to choose: add secundary controller
