Firmware update 4.9 release notes
Where can I find the release notes of the 4.9 version?
  • 4.9
  • Optimized battery life time.
  • Signalization of battery loading fault added - pulsating magenta color. In this case, the charger or cable should be replaced, as they may be damaged and do not provide a constant power supply.
  • Warning:
  • Update can take up to 30 minutes. It depends on Z-wave traffic,
  • If possible, locate the device in the close nearby (ca. 2m) of the Home Center to avoid failures,
  • Wait few minutes after successful update and check if version of device has changed,
  • The update use the Z-Wave network bandwidth to a large extend. It may result in delays in other network actions even several minutes after update.
  • In case of strange device behaviour there may be need of reconfiguration/reinclusion.
    What I miss is the option to see who adapted the temperature and if the valve is open or closed.
    I have the feeling that after some time it doesn’t close properly anymore and heating still gets warm.
    11 hours ago, MacinZ said:
    • 4.9
    • Warning:
    It seems they have removed the update? Cannot update it anymore.
    Yep, lot of issues. Hopefully I didn't make this update yesterday, ufff
    Happy I did not update it yeterday evening... :)
    " to "
    Temat został przeniesiony z "
    " do "
    Unfortunately, I was not so lucky and confirmed update - 2 of 6 bricked. It looks like it was "standard" FIBARO update as usual :-)
    Edited by vacpav
    Same here. 2 dead, 2 OK and 2 left at 4.7...
    Edited by petergebruers
    DNR
    • 1 month later...
    Support told me that the next release will be coming soon.
    Here we go :)
    [16:16:43] ID xx: OK. The device will initiate the firmware update of the target specified in the meta data.
    [16:20:47] ID xx: New image was successfully stored in temporary non-volatile memory. The device will now start storing the new image in primary non-volatile memory dedicated to executable code. Then the device will restart itself.
    [16:22:27] ID xx: OK. The device will initiate the firmware update of the target specified in the meta data.
    Edited by comfix
    [16:39:57] ID XX: New image was successfully stored in temporary non-volatile memory. The device will now start storing the new image in primary non-volatile memory dedicated to executable code. Then the device will restart itself.
     SUCCESS
    Edited by comfix
    [17.01.2022] [16:50:56] [TRACE] [ZWAVE]: ID 487: OK. The device will initiate the firmware update of the target specified in the meta data.
    [17.01.2022] [16:58:10] [TRACE] [ZWAVE]: ID 487: New image was successfully stored in temporary non-volatile memory. The device will now start storing the new image in primary non-volatile memory dedicated to executable code. Then the device will restart itself.
    [17.01.2022] [16:59:52] [TRACE] [ZWAVE]: ID 487: OK. The device will initiate the firmware update of the target specified in the meta data.
    [17.01.2022] [17:01:44] [TRACE] [ZWAVE]: ID 487: An error occured. RGBW program writing will not start
    [17.01.2022] [17:03:44] [TRACE] [ZWAVE]: ID 487: The device was unable to receive the requested firmware data.
    Edited by danidani
    Same here:
    [16:46:34] ID 116: OK. The device will initiate the firmware update of the target specified in the meta data.
    [16:50:57] ID 116: New image was successfully stored in temporary non-volatile memory. The device will now start storing the new image in primary non-volatile memory dedicated to executable code. Then the device will restart itself.
    [16:52:37] ID 116: OK. The device will initiate the firmware update of the target specified in the meta data.
    [17:03:34] ID 116: New image was successfully stored in temporary non-volatile memory. The device will now start storing the new image in primary non-volatile memory dedicated to executable code. Then the device will restart itself.
    [17:05:16] ID 116: OK. The device will initiate the firmware update of the target specified in the meta data.
    [17:05:16] ID 116: An error occured. RGBW program writing will not start
    [17:06:12] ID 116: Application rejected request
    Try again and if still fails take it near my controller.
    2nd time it was a success: [Firmware Update: success]
    Same for me after I moved the device in the close nearby (ca. 2m) of the Home Center. I am going to test it now.
    I took 23 minutes to update it.
    Edited by danidani
    My 3 of 7 updated. No issue so far. All were quite far away from HC3
    same here. RGBW device? @K.Drozynski?
    16/16 successfully updated.
