Yubii Home Center 1.14 Icons
RudyT
Hi Fibaro,
So many icons no longer work since the update yubii app to 1.14 (Quickapp, devices.... )   HC3 5.091.41 Beta.
Dashboard shows everything.
Local Login, FibaroID login nothing help.
Edited by RudyT
  • I did it. Doesn't work!
    I restarted HC3. Multiple Local and FibaroID login. Nothing has changed
    Edited by RudyT
    Did you also try a local login?
    I'm also on 1.14 but my icons are oke. But stil on 5.090
    In my case they sometimes suddenly apear. So no idea why,what is happening.
    //Sjakie
    Try this:
    1. Kill the app
    2. Clear cache
    3. Modify HC3 Secure Connection to "http" (not https/http)
    4. Run the app
  • 5 hours ago, danidani said:
    Try this:
    1. Kill the app
    2. Clear cache
    4. Run the app
    I try it. Nothing helps.
    I try several times local login, no changes.
    Every Icon changed manually is a  sign
  • 34 minutes ago, danidani said:
    I have had the same problem, the current version (5.091 beta) fixed it.
    No, I updated my HC3 to 5.091 weeks ago. In the HC3 Dashboard, i have no problems. It's everything OK.
    The icons are not displayed in the Yubii Home Center app since update to 1.14, 2 days ago. See my first post
    I am sorry, did not checked my version before.
    I have updated my just now and I can confirm one icon for QA of "Generic device" type disapeared. The rest of my custom icons are still in the app. I also tried to clear storage & clear cache, but icons are back except the one for QA.
  • I have to correct myself. Not every device or quickapp with a custom icon is not displayed.
    But the following sensors with custom icon are not displayed:
    multilevel sensor
    generic device
    com.fibaro.lightSensor
  • Why is this so complicated Fibaro?
    It's just an icon.....
    " to "
    Temat został przeniesiony z "
    " do "
  • @K.Drozynski In the HC3 Dashboard in don't missing anything. All icons are available.
    My problem is with the Android Yubii app. I missing icons in the Yubii app.
    Should I still contact support?
    Please do
