How to forcefully remove dead device
Does anyone know how can I remove a dead device from HC3? It is appeare as a not reporting device, which is fine as per the device has been died and not possible to remove it on the right way. I want to remove it completely from HC3. It is fine that I can disable it, but is it possible to forcefully remove it?
Thanks!
G
I you click the  "- " button on your devices tab and choose Zwave.
Then you can click the circle with an cross in it to force remove the device.
    Thanks!
    I have never recognized that during the removal process, the devices can be removed manually.
    Yep.
    Thanks!
     You're welcome
