Ragge 0
Hi!
My first topic!
Changed parameter 30 (temperature threshold) to 15 degrees and took it out from the fridge. When temperature rised above 15
degrees the alarm went on and I got a push notification. But the volume was way to low! If its supposed to wake you up in case of fire
(of course with standard setting of 55 degres) it must be much higher. When pushing the test button on the device I got a
proper volume. I hope that this high volume is standard when it detects smoke but I also want the high volume when the temperature rises above 55 degrees.
Or?
