Green Banana 0
I'm trying to see if there is a log that I can monitor that will show me what's happening on a Fibaro device, speficially Dimmer 2. The electrician has wired up a second switch but randomly working. Yes, this is more likely a wiring issue. But, it want to see if if the Dimmer 2 is recognising a change on SW2 or not when the button is pressed.
I've opened up the console to see if the actions display in there, but nothing displays.
I'm an absolute amateur, so please be gentle if this is obvious.
Drew
