dimmer being added is Multilevel switch?
Rutiga1
I have been adding my fibaro dimmers to my new fibaro HC3.
When I add my Dimmer1s, they show up on the devices table with a Role of "dimmer 2" and in General it shows the Type as "com.fibaro.FGD212"
When I add my Dimmer2s they show up as either "Dimmer 2" like above (what I would expect) or some get added with a Role of "Multilevel switch", and in General it shows the Type as "com.fibaro.multilevelSwitch".
Why are the Dimmer2 being added as "Multilevel switch"?
Does it matter?
Am I adding them wrong?
The "Multilevel switch" has only 41 parameters the Dimmer2 has 59. What am I missing?
Rut.
4 answers to this question
Hmm, as far I see your lower dimmer is in version 2.2 - which means that it is a dimmer 1.
It is ok as it is.
    It is ok as it is.
    But it is a Dimmer2
    I seems to have way less parameters having it like this
  • When the dimmer is added as Dimmer2 I get another 'device' that I can use for the S2 input on the dimmer.
    When it is added as Multilevel Switch I don't get the other 'device.
    Does that matter?
    Edited by Rutiga1
    @Rutiga1 Could you confirm it on device label?
    There should be FGD-212 there, with version 3.x.
    This is really looks like FGD-211 - then version on the label will start from 2.x.
    We can also check it using API, use this URL in browser:
    API_HC3/api/devices/58/properties/productInfo
    and paste the response here.
    Michał
