[SOLVED] Unable to include Fibaro Double Switch FGS-224 in Secure mode
This issue is very similiar to another post, but this time around with a fibaro device (the FGS-224).
I am trying add the double swithc (FGS-224) in secure mode. I have tried to install the switch in non-secure mode and it works like a charm, with the issue that I can not associate directly to another existing device (since it is included in secure mode).
I start to see a pattern -- I have included device in secure mode previously without problems. Why is this now a problem.
If this problem is similiar as the other topic I had with HeatIt-devices, then I would appreciate if Fibaro could list at least the most significant known issues (provided that my assumption is correct, that this is just another example of my previous experienced issue with a HeatIt device).
When I tried to add the FGS-224 it stall after the logs below (then stalls after the last row on parameter 164).
Anyone having any similiar issue?
BR,
Erik
[22:48:32] Home Center in learning mode
[22:49:04] Device added
[22:49:04] Requesting neighbours, please wait...
[22:49:09] Requesting neighbours, please wait...
[22:49:10] Requesting neighbours done.
[22:49:10] Add node status protocol done
[22:49:10] Adding devices complete
[22:49:16] ID 443: Setting value 1 for parameter 1
[22:49:16] ID 443: Setting value 0 for parameter 20
[22:49:16] ID 443: Setting value 0 for parameter 21
[22:49:16] ID 443: Setting value 0 for parameter 24
[22:49:16] ID 443: Setting value 0 for parameter 25
[22:49:16] ID 443: Setting value 0 for parameter 30
[22:49:16] ID 443: Setting value 100597760 for parameter 31
[22:49:16] ID 443: Setting value 33488896 for parameter 32
[22:49:16] ID 443: Setting value 50266112 for parameter 33
[22:49:16] ID 443: Setting value 83820544 for parameter 34
[22:49:16] ID 443: Setting value 600 for parameter 35
[22:49:16] ID 443: Setting value 15 for parameter 40
[22:49:16] ID 443: Setting value 15 for parameter 41
[22:49:16] ID 443: Setting value 0 for parameter 150
[22:49:16] ID 443: Setting value 0 for parameter 151
[22:49:16] ID 443: Setting value 0 for parameter 152
[22:49:16] ID 443: Setting value 0 for parameter 153
[22:49:16] ID 443: Setting value 5 for parameter 154
[22:49:16] ID 443: Setting value 5 for parameter 155
[22:49:16] ID 443: Setting value 255 for parameter 156
[22:49:16] ID 443: Setting value 0 for parameter 157
[22:49:16] ID 443: Setting value 99 for parameter 158
[22:49:16] ID 443: Setting value 255 for parameter 159
[22:49:16] ID 443: Setting value 0 for parameter 160
[22:49:16] ID 443: Setting value 99 for parameter 161
[22:49:16] ID 443: Setting value 0 for parameter 162
[22:49:16] ID 443: Setting value 0 for parameter 163
[22:49:16] ID 443: Setting value 0 for parameter 164
Edited by erik.simonson
Solved
    This one is due to my ignorance.
    The FGS224 is supporting only secure mode S2 while Homecenter 2 currently only support S0.
    Therefore the only option to include the FGS224 with Homecenter 2 is through non- secure mode.
    This could only change if Fibaro offer an update to Homecenter 2.
    • erik.simonson changed the title to [SOLVED] Unable to include Fibaro Double Switch FGS-224 in Secure mode
    • 1 year later...
    Hi, I had same problem with 4.630 version.
    The solution was restore 4.600 (9 month before) and then no problem to include the module :)
    Maybe the version is not the problem...
