Set Alarm Property BREACHED to True
Hello All,
I’m Struggling to find a way to get an ALARM set to BREACHED via Quicapp.
Whenever the ALARM is ARMED – and via an quickapp tries to update Property BREACHED=true nothing happens.
fibaro.call(ID_of_ALARM,"updateProperty","breached",true)
Tried to update the same Property via the Swagger tool, while having the ALARM at ARMED … To see what happens there…
/alarms/v1/partitions/[ID_of_ALARM]
With these Partition:
    "name": "ALARM10",
    "breached": true,
    "devices": [
      136
Server response on the above: 403 Forbidden - "reason": "partition armed"
It seems that an ARMED Alarm can not be triggered to BREACHED via an external command...?
I would expect that the trigger “updateProperty("breached", true)” in the Quickapp is not working for the same reason as could be seen via the Swagger tool.
So, my question here: how can you trigger an alarm that is ARMED to get it in the BREACHED level – other than with an actual Sensor / door sensor / motion sensor etc…?
Thanks,
Arjan
43 minutes ago, ArjanR said:
Hello All,
    "name": "ALARM10",
    "breached": true,
    "devices": [
      136
Thanks,
Arjan
Most likely not.
Can't you make a fake QA  device to breach the zone?
    Hello Jgab,
    Thanks for your reply.
    Already tried that. No luck... Neither getting any error when calling the function.
    Tried with a QA directly acting as ALARM - and then
    self:updateProperty("breached", true)
    And also via a QA to trigger the ALARM by using the ID of the alarm;
    In line of my testing.. tried also
    self:updateProperty("armed", true)
    and
    fibaro.call(ID_of_ALARM,"updateProperty","armed",true)
    Setting the ARMED -> TRUE worked in both cases.. Just not getting the BREACHED set to TRUE
    Perhaps you can answer this - why would you have a QA feature specifically to be set up as ALARM - but not able to get it triggered to BREACHED=true..?
    Thanks,
    Arjan
    Believe found the answer....
    To trigger an ARMED alarm - the call is:
     self:updateProperty("alarm", true)
    Important note here:
    In the call for  disarming the ALARM:
      self:updateProperty("armed", false)
    It is crucial to also call the ALARM to be False (in case it was breached...)
     self:updateProperty("alarm", false)
    If the call  ("alarm", fase) when disarming the BREACHED alarm is not being called together with ("armed", false)  - the next time the alarm is ARMED - the ("alarm", true) won't trigger it to being "breached"
