Walli Controller LED ring control
mi38k
Hi all,
If the Walli Controller is in the Power Supply mode, is it possible to have its LED ring controlled in the same way as for example on Walli Switch or Dimmer? I mean to have it on to work as night light, or change color via scenes etc. According to manual it seems that it is not possible, but if anyone has actually chance to test it, I would appreciate it :). Thanks!
Edited by mi38k
  • mi38k changed the title to Walli Controller LED ring control
@mi38k,
You can try/check that via block scenes actions. If device in HC3 is shown as powered (no battery icon), then it should be possible.
  • Díky Jakube :).
    The thing is, I do not have the system yet, I am just planning and this what I am not sure about. Of course I will try it once I have it, it would just be good to know even before.
    • 3 months later...
  • So, I was finally able to test it and can confirm that in powered mode it is possible to control LED ring via scenes.
