Whatsapp integration with fibaro
ethanmiles
How can I integrate whats app with Fibaro HC2.
I know that this post already exists. The answer given in this post on this forum is an absolute telegram question.
And I want to know, Can WhatsApp be integrated now?
There is a solution they use in HomeAssistant so it could work in HC2. I don’t have experience with the solution:
See:
Yes,
go  to
and get an API key.
Then:
You need one api key to each number you want to send to
[email protected]
I'm receiving the message on my cell phone when I press the QA button, but these messages appear.....please, did I do something wrong?
below the way I did the QA.
Thanks.
local function encode(url)
  if url == nil then
    return
  url = url:gsub("\n""\r\n")
  url = url:gsub("([^%w _%%%-%.~])"function(c) return string.format("%%%02X", string.byte(c))  end)
  url = url:gsub(" ""+")
  return url
function QuickApp:sendMessage(number,apikey,message)
  local url = string.format("https://api.callmebot.com/whatsapp.php?phone=%s&text=%s&apikey=%s",
    number,encode(message),apikey)
  net.HTTPClient():request(url,{})
function QuickApp:onInit()
  self:debug(self.name, self.id)
-- BUTTON send msg 1
function QuickApp:uibuttonw1OnReleased(event)
self:sendMessage("+5511999999999",xxxxx,"Testing whatsapp Msg 1 Fibaro HC3!")
It's just your QA button that is wrong.
You seem to call the button "Whatsapp 1" but your QuickApp function is named "uibuttonw1OnReleased"
5 minutes ago, jorge rintaro said:
[email protected],
ok, Could you please tell me where to fix it?
thanks
What version of HC3 FW are you using?
How have you configured the button in the QA UI? - id, label, onReleased?
My guess is that you should rename
to
function QuickApp:button1(event)
[email protected],
HC3 v. 5.100.22
I thought of a QA where each button would call a whatsapp message.......I don't know if it's the best way to use Whatsapp as alert messages.....
/monthly_2022_02/image.png.c94e19a2feef1d7c994b9ca4dbdc75c6.png" />
If you have
defined in QA deviceID 318
you can do
from other QAs or Lua scenes.
A QA with two buttons becomes pretty static with 2 predefined messages.
The onReleased field in the Button dialogue should be the name of the QuickApp method to call, ex. "button1" will call QuickApp:button1
If you have 2 buttons you need two methods, ex. button1 and button2
[email protected],
thank you very much for the tips..... I made the adjustments now the message (TRACE) appears in the debug panel ......???
I'm studying now QA, a lot to learn yet.....sorry!
1 minute ago, jorge rintaro said:
[email protected],
Yes, the trace is from Fibaro's implementation of the UI handling. A bit annoying but it informs you that you pressed the "whats1" button of deviceId 318.
Hello [email protected], reading most of your tips and tricks - very helpfull. In this case my question: is there a way to send a picture from a ip-cam as a whatsapp-message? E.g. in case motiondetection -> send picture from a camrange...
Thanks in advance.
No, the callmebot that provides the GW to WhatsApp only support text messages.
...but it does support emoticons.
On 2/6/2022 at 4:57 PM, jgab said:
Yes,
go  to
and get an API key.
Then:
Hi
I have changed the mobile number and the apikey  but I have get the following error message>
[DEBUG] 11:48:40: 2022-02-13 11:48:40.672855 [ fatal] Unknown exception: /opt/fibaro/scenes/187.lua:17: attempt to index global 'QuickApp' (a nil value)
What does mean thi?s
21 minutes ago, iTibor said:
Hi
Because you are trying to run the code from a Scene, The code is a QuickApp example.
This should work from a scene.
Hi
Now I have got the following message
[DEBUG] 13:43:11: 2022-02-13 13:43:11.006944 [ error] Handshake error: certificate verify failed
And the number and the api key is okay ...- I have checked the sent link in whatsapp , I have put in browser link and worked
Edited by iTibor
correct text
Try
...or move your code to a  QA...
