Whatsapp integration with fibaro
How can I integrate whats app with Fibaro HC2.
I know that this post already exists. The answer given in this post on this forum is an absolute telegram question.
And I want to know, Can WhatsApp be integrated now?
2 hours ago, jgab said:
Try
...or move your code to a  QA...
Thanks!  Working.
 Hi
 First step: follow the steps (1-3) from the link >
and after you get the activation number make a new fibaro Lua scene like >
local function encode(url)
  if url == nil then
    return
  url = url:gsub("\n", "\r\n")
  url = url:gsub("([^%w _%%%-%.~])", function(c) return string.format("%%%02X", string.byte(c))  end)
  url = url:gsub(" ", "+")
  return url
local function sendMessage(number,apikey,message)
  local url = string.format("https://api.callmebot.com/whatsapp.php?phone=%s&text=%s&apikey=%s",
    number,encode(message),apikey)
    net.HTTPClient():request(url,{  options = { checkCertificate  = false }})
sendMessage("activated mobile number",apikey,"Test text");
Working with iphone WhatsApp, but I didn't get on Android. I don't know why and the received link working.
On 2/13/2022 at 2:12 PM, jgab said:
Try
Hi
I have made this changes and working, I get the messages on iPhone's whatsapp, and I activated on a second number with android whatsapp, and the received link working on this one but the messages sent trough this script doesn't arrive on Android's whatsapp (different activated mobile number).I get messages only on iPhone.
Do you know why ?
@jgab @iTibor
Hi guys.
I'm new in Fibaro world (I had a Vera Secure controller before) and I have a HC3 that I would like to connect to Whatsapp.
So generate an API key and I create a QA with this code you share here in the Action panel:
and it works correctly.
I need to send a whatsapp message when, for example, a sensor door is open.
I created a LUA scene with the condition that the window sensor is open. Then I wrote this in Action panel (with my numbers, of course)
And activate the scene but it doesn't seem to work.
What am I doing wrong?
Thanks!
Edited by COAT
12 hours ago, COAT said:
@jgab @iTibor
Hi guys.
Thanks!
Are you sure the scene triggers? Print a log.
Do you see anything in the log of QA 318?
Add a log.
Add a log.
Hi, thank you for your answer.
I am sure about the scene trigger because I setted that a message should be sent and a light should turn on when the door is opened and the latter works fine.
But adding a log for sendMessage function and for the url I found that received parameters were wrong.
I'll explain.
In the scene I wrote
In the log i read this
As you can see, the "plus" symbol was read as a "space" before the number but, in my string, I hadn't blank space in url function
So, I deleted "+" from the scene function and added it in url
I try again and in log file I read
(I think that the "%21" is the encode of "!" character)
I don't know why but it works.
Is it possible the string in LUA (from the scene) are coded differently in QA function?
Yes, you ran into the "bug" that parameters are transformed in fibaro.calls.
I did a test of your code but between 2 QAs and there the '+' survives so I didn't bring it up. From a Scene it's a different matter...
Here is a post I did some time ago with more "interesting" transformations of arguments.
Hi
I have migrated from HC2 to HC3 (5.120.10)
And my whastapp notification stopped to send message
Can you help me?
The Lua scene looks like this>
DECLARATIONS panel:
ACTIONS:
  if url == nil then
    return
  url = url:gsub("\n""\r\n")
  url = url:gsub("([^%w _%%%-%.~])"function(c) return string.format("%%%02X", string.byte(c))  end)
  url = url:gsub(" ""+")
  return url
sendMessage(MYNUMBER,APIKEY,"message");
Hi @iTibor, my functions are a little bit different from yours.
in the url, I added a "+" before the "%s" in "phone".
So, my string is:
Otherwise the function didn't work.
Furthermore,
I have not " options = { checkCertificate  = false }". So, my string is:
but I don't know the differences.
At the end:
MYNUMBER, in my case, is a string. So,
I hope this help you
Hi @COAT
Thank you and I have made changes like you suggested: ( so my LUA script look like this - in ACTIONS panel
  if url == nil then
    return
  return url
  local url = string.format("https://api.callmebot.com/whatsapp.php?phone=+%s&text=%s&apikey=%s",number,encode(message),apikey)
   net.HTTPClient():request(url,{})
sendMessage("+11111111111",123456,"new code message test ");
of course I put my number and my apikey
but still I didn't get anything
Edited by iTibor
Hi @iTibor
You have to remove the "+" in sendMessage so your last row will be
Otherwise your phone number will have two "+" (one for local.url and one for sendMessage) and you'll send the request to "++11111111111" ?
Hi @COAT
I have tried like this to:
sendMessage("41111111111",123456,"new code message test 2 ");
but still I don't get the message on whatsapp
Ah wait @iTibor!
I think that there is a mistake in your code that I haven't noted before.
I assume that you added a Quickapp device.
You wrote
but the correct syntax is
without "local" before function and with "QuickApp:" before function name.
Therefore, you have to add a QuickApp function where to invoke "sendMessage" function itself.
So your code will be:
Then you have to add the function name in "onReleased" section of your button like this
/monthly_2022_11/image.png.0e77d8ef94ace5bd24b259e1def146e7.png" />
I tried to create a scene where, when something happens, the button of my QuickApp is pressed and a whatsapp message is sent to me
It works for me, this way.
I'm new in Quickapp stuff
I have made a new Quickapp  like this>    -still not working
Edited by iTibor
Hi @COAT
Working!
 Thank you very much.... now I have to find how is working this Quickapp stuff
13 hours ago, iTibor said:
Hi @COAT
Working!
Glad to hear it ^_^
how can we/I call this function from any other Scene?
Hi @emielstroeve
In the block scene you have to select the trigger option(s) and on the execution part you have to select this the Whatsapp sending Quickapp and /press button and choos the button, and working
