Fibaro HC3 and Elero
I'm planning to buy HC3, now i'm running HC2.
I wonder if it's possible that HC3 can handle Elero devices.
I bought new Roller shutters and they advised me to buy the elero hub to control them.
Since the Elero Hub costs about 300 € i think it will be better to buy HC3 but i don't know if i can control those roller shutters with HC3
These roller shutter work with solar power so there are no cables.
4 answers to this question
Hi @Lode,
HC3 serves as elero HUB. Though I do not know which device series are supported by HC3.
    Hi @jakub.jezek
    Thanks for your reply.
    It's a little bit confusing.
    I found a list of products that are supported by the elero hub wich you can find
    Does that mean they are also supported by HC3 ?
    Fibaro ? Is there a list available wich devices are supported ?
    Edited by Lode
    @Lode, If I were you I would contact Fibaro via [email protected] with request if your Elero devices are compatible, which they should be I think.
    Maybe next day call in about your request and they probably send you some list.
    @jakub.jezek
    Thanks again.
    I will do that.
