xristos 0
Hello everyone !
I have a Problem ! I am trying to Dim my HVGC-480-L-AB mean well Led drive where support 3 dimming ways :
※3 in 1 dimming function (for B/AB-Type)
Output constant current level can be adjusted by applying one of the three methodologies between DIM+ and DIM-:
0 ~ 10VDC, or 10V PWM signal or resistance.
Direct connecting to LEDs is suggested. It is not suitable to be used with additional drivers.
Dimming source current from power supply: 100μA (typ.)
So when I plug everything is working fine in the first place but my problem starts when I try to dim until off or when I push the off button from the home center interface or from the push button directly connected on the flush dimmer 0-10v its starting to flashing the led strip and it dosn't stop !
In the video you can see what is happening after the off button.
Plz any help I would be grateful !!!
6 answers to this question
