1) import QA
2) change in code
3) save
4) check log
should be
5) now you can check motion or check your doorbell button
TODO: get motion / ding snapshot
/monthly_2022_02/image.png.ee640b15dd4b453a273a0804116774f2.png" />
Edited by 10der
  • Like 5
    UPDATE: now with banana taste
    Oke, nice. Let me test.
    I already got a working solution with HA and protect. But this is nice.
    So, just to make it clear.
    In the config, edit the local IP of the G4 doorbell.
    Add, the username and password i use for local login.
    Add the name as given in the GUI of the doorbell.
    [13.02.2022] [15:11:00] [WARNING] [QUICKAPP388]: Wrong status '404' in response![13.02.2022] [15:11:00] [ERROR] [QUICKAPP388]: QuickApp crashed[13.02.2022] [15:11:00] [ERROR] [QUICKAPP388]: main.lua:115: attempt to call a nil value (upvalue 'err')
    please stay tuned... let me check
    @ppeterr can you shoe me a full log?
    No route to host :) - I'm using the IP from the doorbell.
    [13.02.2022] [17:55:55] [DEBUG] [QUICKAPP390]: onInit[13.02.2022] [17:55:55] [DEBUG] [QUICKAPP390]: DoorbellMotionSensor init[13.02.2022] [17:55:58] [ERROR] [QUICKAPP390]: Connection error: No route to host[13.02.2022] [17:55:58] [ERROR] [QUICKAPP390]: QuickApp crashed[13.02.2022] [17:55:58] [ERROR] [QUICKAPP390]: main.lua:122: attempt to call a nil value (upvalue 'err')[13.02.2022] [17:56:00] [DEBUG] [QUICKAPP390]: onInit[13.02.2022] [17:56:00] [DEBUG] [QUICKAPP390]: DoorbellMotionSensor init
    AHH!
    your accessing the udmp
    [13.02.2022] [18:02:28] [DEBUG] [QUICKAPP390]: onInit[13.02.2022] [18:02:28] [DEBUG] [QUICKAPP390]:
    Edited by ppeterr
    No route to host
    nice!
    1 minute ago, 10der said:
    No route to host
    nice!
    And it works
    [13.02.2022] [18:07:35] [DEBUG] [QUICKAPP390]: child 390 turned on
    This is nice, now i can dump HA again. Since home assistant was only calling a script to let alexa talk. And say "someone is at the door".
    My own solution can do that alreadty on the HC3! I only needed a binary trigger for the G4.
    Next up, trigger a routine that plays a feed on my Echo show. Already got that running with
    And then my life is complete for today :P
    Great!
    if you wanna got own face you can
    where 1234 is motion or ding Unifi QA
    img - is base64 encoded png file
    <img src="data:image/png;base64, %img" />
    @ppeterr Peter. strange question. i am a dummy in amazon etc. now ring via cloud saying  "someone is at the door"
    how i can pass message to my old Amazon echo 1 to speak "someone is at the door". what a script you are talk about and last - is the paid service?
    Edited by 10der
    No, its free.
    I am running a LAMP server with a little piece of PHP
    That PHP triggers a script on my server (syno nas, but before a rpi / ubuntu)
    That script sends a TTS cmd to amazon.
    My echo show, speaks the command :)
    I have a qa that inserts a variable to the PHP, so i can make alexa say anything from the HC3
    Sir. developing is not a problem
    repeat again
    how
    please!
    script - need LAMP an JD (decrypt json)
    Simple PHP - edit path
    And the quickapp.
    That script can also trigger routine's on the echo show, so with your quickapp. I can send
    a command to the echo show, that shows my feed from the doorbell :) YAY!
    ohhhh
    sex with amazon cookie
    also i thing i will have another sex with expire this token....
    oh no
    11 minutes ago, 10der said:
    ohhhh
    oh no
    yeaah, no problem at all with the new solution for that. I have sexy with alexie all day/week month....ehhh forever ......it works :)
    @10derHow is she doing ? :)
    Thanks to your quickapp, alexa now announce when someone is at the door.
    Next up, integrate it with "scrypted", so it will announce the name if recognized.
    Edited by ppeterr
    Welcome Sir
    btw, my old Alexa 1gen echo now in trash bin
    google mini and direct chromcast Proto playing is very easy ;)
    Next project ?
    Make your doorbell do a little fart :P
