18 minutes ago, ppeterr said:
Make your doorbell do a little fart :P
That didn't worked out fine with Tesla in the USA. They had to remove the farts :-)
    8 hours ago, ppeterr said:
    Next project ?
    i know. ? Chewbacca ding
    On 2/13/2022 at 6:18 PM, 10der said:
    if you wanna got own face you can
    where 1234 is motion or ding Unifi QA
    img - is base64 encoded png file
    <img src="data:image/png;base64, %img" />
    If this is not used, what happens with the data ? Where does it allocate ?
    in userDescripion in QA :D
    Just asking, because i noticed (and maybe it was also before) that the ram has filled to 96%, with 42% cache.
    • 2 years later...
    Any update on this QA ?
    The button detection works, motion is not.
    I'm using Unifi Protect and login was successful and button press is detected.
    Edited by GeeMoney
    • 3 months later...
    I made some changes to the QA posted somewhere above:
    - Did some code restructuring
    - Changed the getEvents logics a bit: it missed motions/rings because camera's can have a small delay sending events to Cloud Key, which were missed when getting events
    - Rewrote code so it uses childDevices for each camera / doorbell to support multiple devices
    - When device is doorbell a motion sensor + ring child device is added. If camera: add motion sensor
    I did remove the snapshot functionality however, so if you want that you should take a look at the old QA  how it was implemented.
    Before using, set the 3 variables in the 'main' file of the quick app, see attachment.
