Mark Manning 1
I currently have an HC3 master and an HC3L which I have just added as a slave. The master is in the main house with all of the devices connected to it, but I also have a separate office building with LAN connection between the two (The office currently has an HC2 which is to be decommissioned and it has far fewer devices!).
Because the office building has a UPS I want to move the more expensive HC3 in there and use the HC3L in the house, where it will be kept in the attic, get very hot and very possibly suffer a reduced lifespan. I cannot find a way to 'transfer' devices between connected controllers, which seems a ridiculous limitation, does anyone know if there is a way to do it, or is the only possibility to remove every single device and re-associate each and every one with the new controller? This also raises questions about what would happen if one of the controllers dies, I would have thought that it would be possible to connect a new gateway and move all of the devices over to it, so what exactly does happen?
Some of the devices are in extremely hard to reach places and it seems ludicrous to need to physically access a device when it is already under the control of a gateway on the network.
5 answers to this question
