Don't reboot. Patiently wait, it can take up to an hour... It will go back to the previous version.
I have the same problem have tried three times with the same results. Have run a repair after each attempt.
@PedroChacon and @oanamattias -  This is an annoying situation, I can relate to you, I am not a newbie and have had issues like you. Take your time to read up on "recovery" and take your time to make decisions.
You both have a recent backup, right? Better ask now before you do anything that makes things worse... This is advanced stuff and you probably have not done this before.
If you cannot boot a HC3 (or yubii) into a "running state" (so no website, and Z-Wave does not work), I would enter "recovery" mode and first try a switch system (If "A" is active switch to B)...
Go to this website:
And read the chapter on "Recovery" under "Maintenance". There are several options, for example, you can install a different firmware version and restore your data, with or without history.
Use this site to connect to your HC3 in case you cannot find it, it might have changed its IP address
If you want the previous firmware image (or any other version, just change the version number in the URL) you can go to:
Good luck!
    After a few hours I looked and it was working, but the update has not been carried out, I will wait for the next version to update, since it had a recent backup, the only thing that has happened is that I wasted my time without further ado.
    Anyone else experiencing problems after update?
    If someone experienced this issue please download logs from the system after switching back to working version (using <gatewayIP>/api/service/logsDump path).
    Please send me the archive in PM, it will help us resolve this to next version.
    Michał
    My learning with Fibaro in general is: Skip all Beta releases, I only update with final/stable releases and overall I run a very stable HC3.
    Allthough sometimes it is tempting.....
    I would prefer that the update light on the box will someday only trigger on a stable release.
    @oanamattias, looking at your HC3 SN, is it pre-production unit or produciton one?
    In case of pre-production (Alpha) unit there is missing NICE eeprom, that is need for 5.101 onwards, so 5.100.22 is terminal release for pre-production units. I too faced this problem and I contacted support if its possible to install eeprom in my HC3. Seems It is possible, but you would have to send Home Center in.
