Neo Andersson 232
Hi
Did the syntax of sending notifications change?
I noticed some weird syntax when converted Block scene to Lua.
What is the right syntax then?
If you convert a block scene to LUA you see this command: hub.alert('simplePush', {[1] = 803, }, 'Haho', false)
when you try to use the same syntax in other LUA script it throws errors. He doesnt understand the hub function and when i use the old fibaro.alert('simplePush', {[1] = 803, }, 'Haho', false) formula is says only push or email parameter is allowed.
So i tried fibaro.alert('push', {[1] = 803, }, 'Haho', false) version, that works, so why is the syntax different ?
Dear Fibaro, can you make it clear please?
Edited by Neo Andersson10 answers to this question
