I want to find for a specific device, all the scenes it is used in. How can I do this, without needing to open every scène and write down the devices I find in there?
I belive you can't do this. You need to open them one by one.
If aim wrong, i will be very happy.
You can get the scenes triggering on a device.
  • Like 3
For sake of completeness, for a binary switch I used property = "state", instead of property = "value". It doesn't seem to accept a wildcard here, nor can you leave out that part of the JSON query. Is there a trick?
No, I think you need to specify the property.
I believe this is the mechanism used by fibaro to find the scenes to test the condition for given an incoming event.
Thanks. Probably many power users on this forum tackle this question in a different way: get all scenes and all QucikApps on our PCs and do a "grep"
Oleg posted a Python script once, and then we discussed this, but we never came to a consensus on how to write a universal way. That script may still work, I haven't used it since it was published
I hope Oleg is OK, he has bigger issues at the moment... in Ukraine.
Edited by petergebruers
Yes, I have similar code. It's a bit more complicated now as QAs can have multiple files and conditions part of a scene where ids can hide
To catch a bit more of usages you need to do some "simple" variable flow tracking too. Like
etc.
