I updated to 5.102.23 (beta) en there is Zigbee support ?
Added Xiaomi Mijia Smart Temperature and Humidity Sensor  without problems ?
Who have other devices who works with Fibaro HC3?
  • Like 5
i have OSRAM SMART+ LED Stripe its working and ikea trådfri e14 400 lumen
And ikea Led power supply Model icpshc24-10eu-il-1 only white and dim ?
Edited by Ekenswe
ikea lamp
HUE?
1 hour ago, Sjekke said:
HUE?
Should be working. Focus is now on Zigbee lighting.
Edited by jakub.jezek
" to "
Temat został przeniesiony z "
" do "
14 godzin temu, Sjekke napisał:
HUE?
I've tested and it's working
  • Like 4
Are they now catogarised as lights ?
They looked like this, Oświetlenie means lights
Thanks @marczu_83
I just switch to HC3.
In HC2 they were just a VD.
Now finally catogarised as lights...nice improvement !!
@marczu_83
Any specific procedure to add them to the HC3?
Can you change the color, etc…
my HC3 goes in recovery mode after updating. If I choose repair, it goes back to previous FW (which is working)
4 minuty temu, Sjekke napisał:
@marczu_83
Reset Hue bulb -> delete it from hue app,
add new zigbee device from hc3 gui and wait until it detects it.
I'm not at home so i can't answer how changing color works:)
I tested some HUE some time ago and only RGB (RGBW bulbs) or single color dimming worked (CCT or single channell devices).
LED lamp  AQARA ZNLDP12LMWall Plug  AQARA SP-EUC01
does not work, the scan does not find the lamp and socket
Edited by alex_optek
It worked! ?
How do you control HUE in a scene?
Hello everyone,
I have some difficulties to add my zigbee rolling shutter :
[09.04.2022] [17:52:24] [TRACE] [ZIGBEE]: Waiting for adding process to start.
[09.04.2022] [17:52:48] [TRACE] [ZIGBEE]: Device identification process started.
[09.04.2022] [17:52:48] [TRACE] [ZIGBEE]: Device added to the network.
[09.04.2022] [17:52:51] [TRACE] [ZIGBEE]: Device identification process started.
[09.04.2022] [17:52:51] [TRACE] [ZIGBEE]: Device added to the network.
[09.04.2022] [17:54:02] [TRACE] [ZIGBEE]: Adding process finished.
But I don't have any Zigbee device in my HC3 ?
When I tried to re-add the same device, I got the next log
[09.04.2022] [18:13:00] [TRACE] [ZIGBEE]: Waiting for adding process to start.
[09.04.2022] [18:13:17] [TRACE] [ZIGBEE]: Start removing the device.
[09.04.2022] [18:13:17] [TRACE] [ZIGBEE]: Device removed.
[09.04.2022] [18:13:18] [TRACE] [ZIGBEE]: Start removing the device.
[09.04.2022] [18:13:18] [TRACE] [ZIGBEE]: Device removed.
[09.04.2022] [18:13:21] [TRACE] [ZIGBEE]: Device identification process started.
[09.04.2022] [18:13:21] [TRACE] [ZIGBEE]: Device added to the network.
[09.04.2022] [18:13:22] [TRACE] [ZIGBEE]: Device identification process started.
[09.04.2022] [18:13:22] [TRACE] [ZIGBEE]: Device added to the network.
[09.04.2022] [18:13:25] [TRACE] [ZIGBEE]: Start removing the device.
[09.04.2022] [18:13:25] [TRACE] [ZIGBEE]: Device removed.
[09.04.2022] [18:13:28] [TRACE] [ZIGBEE]: Device identification process started.
[09.04.2022] [18:13:28] [TRACE] [ZIGBEE]: Device added to the network.
[09.04.2022] [18:13:31] [TRACE] [ZIGBEE]: Start removing the device.
[09.04.2022] [18:13:31] [TRACE] [ZIGBEE]: Device removed.
[09.04.2022] [18:13:34] [TRACE] [ZIGBEE]: Device identification process started.
[09.04.2022] [18:13:34] [TRACE] [ZIGBEE]: Device added to the network.
So the rolling shutter seams to be really added, but I can't see it on my HC3.
Anyone have an idea what I have to do ?
Maybe it's a bug, in this case how to report it ?
Edited by Maths
Aquara Door & Window Sensor MCCGQ11LM Works :)
This early Zigbee implementations should be focused on Zigbee lighting and occupancy. I do not think that shading and devices that are not in complement with Zigbee lighting will work.
What do you mean by reset Hue bulb ? The Hue bridge ?
And delete the bridge from Hue app ?
