After the last HC3 firmware upgrade, question marks as icon
Hi
If a connect directly without a gui to HC3 all icons are ok.  The lamp controlled by the fibaro dimmer modules shows as icon a lamp, but on Android and on IOS the presentation is a question mark.
I do have the issue on many but not all.
Any ideas?
5.102.23 (beta)
4 answers to this question
There is small fix for that in next App release.
    Firmware  5.110.15  solved the issue.  With this presentation layer it's more easy to modify the icons.  Did have some issues with qubino micro dimmers which didn't react well, after including again resolved.
    Edited by Tikilauda
    I am longer time observing similar bug on iOS Yubii app (HC3 currently running 5.131 beta).
    My custom 128 x 128 png icons display correctly in device OFF state. When turned ON, device icon is replaced by a question mark.
    When I use any of FIBARO predefined icons, they display correctly in both ON and OFF states.
    However, in the PC web interface, my custom made icons display correctly for both ON and OFF pictures.
    So the bug should be in the Yubii app syncing the off state icons.
    It is fixed in upcoming Yubii app update.
