JcBorgs 52
Simply trying via api.get and api.put to read and write the “Energy panel Tariff rate value”. api.get works just fine and I can read the “rate” value without any issues. But when I try to write a new value with api.put I simply can’t get it to work.
Anyone with any good knowledge around the api.put command in Fibaro that can assist and solve this problem?
In the Energy Panel Settings the Tariff value is put to 0.64 before the code is executed
Current code in testning:
--Define data to put
7 answers to this question
