help with net.HTTPClient()
Any experts on the net.HTTPClient() coding in here?
Am trying to build a QA for my car charger (Charge Amps HALO) and have access to the REST API. They have a bit different implementation to what I have worked with before, you need to login with email, password & APIkey to get a ”token” that you then use in other request. If I do this login on their swagger page I am able to get a token and then build a simple function to pull out information about my Charger, and this works just fine:
Code:
function QuickApp:GetData()
  http = net.HTTPClient()
    local url = "
d"
    local requestBody = '
d'
    local token
="aabbccddeeffgghhiijjkkllmmnnooppqqrrssttuuvvwwxxyyzz"
    http:request(url,
            options = {
                data = requestBody,
                method = "GET",
                headers = {
                           ["accept"] = "application/json"
                           ["Authorization"] = "Bearer " ..token
         success = function(response)
                      print("response status: " ..response.status)
                      print("Response data: " ..response.data)
Request URL from the Charge Amps swagger page>
Curl from the Charge Amps swagger page>
200
Response body from the Charge Amps swagger page>
Log output in Fibaro HC3>
[21.04.2022] [18:34:25] [DEBUG] [QUICKAPP977]: response status: 200
[21.04.2022] [18:34:25] [DEBUG] [QUICKAPP977]: Response data: [{"id":"XXXXXXXXXXXXXXX","name":"XXXXXXXXXXXX","password":"XXXXXXXXXX","type":"HALO","isLoadbalanced":true,"firmwareVersion":"72","hardwareVersion":"2","ocppVersion":null,"settings":null,"connectors":[{"chargePointId":"XXXXXXXXXX","connectorId":1,"type":"Charger","settings":null},{"chargePointId":"XXXXXXXXXXX","connectorId":2,"type":"Schuko","settings":null}]}]
So the above part are working just fine, sensitive information have above been replaced with bogus information. But the issue I have is that I want to do another ‘function’ that handles the login to get a token (there is a login “swagger”on the Charge Amps swagger page) that can be stored in the HC3 as a variable, the  “tokens" are only valid for 2 hours and need to be regenerated several times each day to keep the QA working.
To be able to do this you need to provide apiKey, email & password, but I can’t get that to work….. Doing it on the Charge Amps swagger page works just fine, but need this in a ‘function’ in the QA to be able to automate the collection of ‘token’ :
Code I have tried:
function QuickApp:CAlogin()
 local requestBody = 'https://eapi.charge.space/api/v4/chargepoints/owned'
 local APIkey = "xxzzyyxxzzyyxxzzyy=="
http:request("https://eapi.charge.space/api/v4/auth/[email protected]&password=aabbccddeeff",{
    options = {
               data = requestBody,
               method = "POST",
               headers = {
                          ["Content-Type"] = "application/json",
                          ["accept"] = "*/*",
                          ["apiKey"] = APIkey
                        print("Status", response.status)
                        print("Data", response.data)
                        end,
              error = function(message)
                      print("error:", message)
This simply doesn’t  work and just gives a 400 as status code in the Fibaro log. But how do I do a net.HTTPClient() request that includes apiKey, email and password as required by Charge Amps? Tried to put email and password in the URL but that does not seem to work. Have also tried to put it in other parts of the code but it simply doesn’t work, always gives me a 400 status code.
Edited by JcBorgs
Try this
    12 hours ago, jgab said:
    Try this
    @jgab
    Did a typo at first and it didn’t work at all…. just gave the 400 code again..
    But corrected this and now work as it should!
    Thank you!!!
    Edited by JcBorgs
    you might try to urlencode everything starting with ?,
    or send the data without json.ecode, like
    Got it working with tip from @jgab
    Now I just need to figure out how to store the token part of the data received into an variable, not an coding expert so tips are highly welcome..
    I don't think you should store the token in a QA variable.
    I believe that the structure could be something like this
    A more complex logic would renew the token first when you get an expired token error back from a request.
    I assume that getting a new token using the refreshToken is different from the initial log in procedure.
    @jgab Amazing quick work, and with such high quality! You brought up several good solutions that makes the QA so much better.
    Have verified everything and it works just perfect, added code for the renewToken part and tested with a “button”, all works without any issues. Did change the names of a few local variables to limit confusions.
    Did like the idea to split code in cmd/button, but unfortunately in the ChargeAmps implementation there are different “headers” variables for different command so don’t think this will work in the end. But a question regarding the ‘cmd’ part, obvious what the method and path are for but what are the intention with the ‘cont’ and how should that be used?
    You gave me such a good help and an excellent ground to build upon. Will be adding some more buttons and labels and build upon what you provided to make a QA to handle the Charge Amps charger with. Also in the process of building scenes that combines functions/data from the Tibber QA and the ChargeAmps QA with the intention to charge the car when the energy cost are as low as possible.
    The idea with cmd is of course to have a tailor made http function that makes it easy to talk to the api. It becomes a bit like http:request but more dedicated....
    The advantage is that the code should be smaller, collecting common http code in one place. The drawback is that it requires many optional arguments as the http requests are a bit different (ex. headers).
    So I made another proposal for :cmd that makes additional/optional parameters easier to handle. See below.
    In Lua you can send a table as argument to a function
    That can also be written as
    i.e. without the surrounding ().
    The function foo is defined with one parameter
    and args is bound to the whole table passed to foo.
    The reason for allowing this syntax is that we can have "named parameters", and the parameters can be passed in any order (as key-values in a table don't have an order).
    We can also check if a value is present and if not provide a default value if we want.
    Making self:cmd of that type we can make it a generalised cmd for all the api calls.
    The 'cont' parameter is a function that is called with the resulting data. It's a bit like the success function in a http:request. In the QuickApp:button1 it just prints the result. In login/refresh it updates the token variables.
    In the new version it's called 'response' and should be a function that takes an argument that is the json.decoded response
    @jgab
    Will dig into your updates shortly…
    But have one thing that gets me into trouble>
    The response body from the “login” starts like this:
    And it is easy to assign variables data from the response like tokenCA =data.token
    But in the chargepoints owned respons body starts like this:
    And when trying to assign variables data from the response like CAid = data.id the CAid just ends up empty.
    Do understand that something is needed to be added to the data.id to get ”deeper” into the data, but what?
    And also if I as an example like to get “type” from the second connectorId I can’t just do data.connectors.type, how to specify which of the to “type” fields I will get?
    8 minutes ago, JcBorgs said:
    @jgab
    So the result is an array of key-value tables.
    To use the first item (can there be more then one? Maybe if you have multiple accounts/chargers?)
    also the .connectors field is an array, to get the first do
    Here I don't know if they are always sorted on connectorId or if you need to search for the id you need.
    @jgab
    The new version crashes for some reason:
    Log output:
    [22.04.2022] [12:10:06] [DEBUG] [QUICKAPP978]: Charge Amps HALO 978
    [22.04.2022] [12:10:06] [DEBUG] [QUICKAPP978]: Calling /v4/auth/login
    [22.04.2022] [12:10:06] [DEBUG] [QUICKAPP978]: Status /v4/auth/login - 404
    [22.04.2022] [12:10:06] [ERROR] [QUICKAPP978]: QuickApp crashed
    [22.04.2022] [12:10:06] [ERROR] [QUICKAPP978]: main.lua:69: attempt to index a nil value (local 'data')
    Line 69:
          tokenCA = data.token
    Also realized one thing, in almost all other available commands the “id” from the ‘charge points owned’ are needed as a variable. So will implement that during the login the QuickApp:button1() is called and populates a variable just as token and refreshToken are being done in the Login.
    Sorry, I'm flying a bit blind here....
    In :cmd it should not be a trailing slash in the url. It should be
    (I changed in code above too).
    The reason is that you want path argument to start with a slash, like "/v4/chargepoints/owned" - just because that's how it is usually specified.
    Anyway, this brings up the check for errors. It seems like a wrong url still ends up as a success (response call) - so you probably need to check if the status is < 206 to treat it as a success. Do that in :cmd.
    Ex.
    @jgab
    Works just fine now!
    Your updated code is probably the best way to do it, but for someone that doesn’t possess your coding skill it starts to look really complicated ? and when/if something goes wrong it would be hard for me to find where the problem is….
    Will probably revert back to something like the original code you suggested, then add all the features, buttons and functions I want in the QA, will most likely be a really long code. When that is completed and I have full understanding how it work I will start to include your new and more smart methods. I need to learn more, start simple and then enhance over time.
    Thank you very much for all your effort and all of the detailed explanation, have learned so much from this!
    @jgab
    Spent some time on this over the weekend, managed to get a fully operational QA and then did an effort in trying to learn the method your code was built in and eventually managed to understand it and implemented it on the code I hade done. It actually reduced the number of code line from a bit over 500 down to less then 300.
    My code is probably far from optimal but at least it is working and now have a fully functioning Charge Amps QA:
    Edited by JcBorgs
    Minor updates
    Hi, great with this code, I see you have not published the QA in MarketPlace, are you planning to do so?  or can you share QA in other channel?  Håkan
    @Håkan Enhager
    No I have not publish it, actually it has expanded a lot since I now also have included a “Smart Charging” function in the QA that works together with the Tibber Monitor QA to find the 4 cheapest hours to charge the car.
    Have some minor cleanup work to do and then it will be published.
    @Håkan Enhager
    Attached to this post is a scaled down version of the ChargeAmps QA without the SmartCharge functions (that requires Tibber Monitor QA)
    To be able to use this QA you need a Charge Amps API Key, you can request that by contacting Charge Amps support [email protected].
    You will need to put in your Charge Amps username, password and API key in the variables in this QA
    If you also have Tibber and uses the Tibber Monitor QA I can provide the current version of the full Charge Amps QA which also has a smart charging feature that works together with the Tibber Monitor QA and finds the cheapest slot of 1-10 hours (configurable how many hours you want). The Tibber Monitor QA has 11 hours that we can use to calculate the best time to charge the car, I do the calculation at 20:00 and always has a fully charged car in the morning at the lowest cost.
    Hi, thanks a lot. I am running tibber monitor as well, would be extremely helpful also with the other QA! Just sent a request to CA asking for the key as well.
    Thanks again and have a nice day
    @Håkan Enhager
    Attached is the current version of the Charge Amps QA with the smart charge function.
    The principle is that every day at 20:05 it finds the cheapest block of 4 hours during the coming 11 hours and then automatically starts and stop the charger.
    The time when it does the calculation can be changed with buttons in the QA and the amount of hours can also be changed with buttons in the QA.
    It might not be perfect but has been working good for me the last couple of month.
    If you what to use this version, the other version without smart charge should be removed from your HC3.
    Very nice, thank you very much! Now just waiting for the API KEY from ChargeAmp!   Next weeks challenge will be to  find a good 24V Thermostat for Floor heating (water)  that looks good!  But thats another topic...
    Your welcome, please reach out to me if something isn’t working in the QA.
    24V Thermostat for Floor heating… sorry cant help you there😆
