tzimber 3
Hi Everyone,
I couldn't find any thread on this issue.
So,
connecting an IP camera to HC3 seems to be pretty simple.
what can I do when I have a POE NVR ?
I have a Dahua 5XXX series NVR, with POE enabled.
so basically, all the cameras connect directly to the NVR, and the NVR switch is the one that provides them addresses.
the address pull would be 10.0.0.X / 250.255.255.0
my router is using a different network (that's the way it should be) - 192.168.2.X /255.255.255.0
The NVR is connected to the router, it has internet connection, and I can connect to it and all the feeds.
when looking on the add camera option on HC3 it askes for an IP address.
obviously, HC3 that is connected to 192.168.2.X will not be able to get to a camera that is on 10.0.0.X
so the only way to get to the video feed is if there is a way that the HC3 can connect to the NVR, and not directly to the camera.
I find it hard to believe that there isn't a solution for this as many people use POE NVR this days..
so if anyone has an idea, ill appreciate it.
Thanks !
4 answers to this question
