Impossible to switch on the Local Protection for Implant
I cannot turn the Local Protection ON for my Implant. Does it work?
When I try to switch it ON, it automatically turn OFF after few seconds (see video).
HC3 software 5.110.15, Implant v.5.2
Edited by deso01
7 answers to this question
Video doesn't work for me. But smart implant local protection works fine for me on HC2
Hi @deso01,
Please try following command in Lua scene:
    Thank you for the idea, but nothing happened ((
    Ok now it's looking like a bigger issue
    I have exactly the same issue with a HC3 (FW 5.110.15) and a new Fibaro Smart Implant (FW 5.1, connected with security level S0). I've tried different browsers. The slider always slides itself back to the left within a few seconds.
    I've tried reconnecting the Fibaro Smart Implant without security and upgrading it to 5.2 - no change to the problem.
    I found a way to enable it though - enable "Local protection" in the Advanced page of the "Relay switch" device for the Input/Output you want to configure.
    /monthly_2022_05/image.png.ada725152e73b0104c5bf608d8b2ea87.png" />
    Once that's done, the local protection for the Input/Output switch is enabled when you look at it in the Advanced page for the Configuration device!
    We will check it out, thanks for the report.
