  • 3
Adding photovoltaic system to HC3
Hi all,
In the coming months I am going to install a photovoltaic system in my house, specifically the inverter GW5000-EH of GoodWe. And I have two questions:
1. In order to include the energy production on the following screen:
/monthly_2022_05/image.png.b5b88dd6ae335906b16c5c0f039b98f6.png" />
what Zwave device do I have to buy to make this measurement in my house with a single-phase installation? Some devices I thinks that I can be use, but I'm not sure if their are compatible with production settings at HC3, are:
AEOTEC Clamp Power Meter
- Quibino Smart Meter
How I can configure the new Zware device in HC3 to indicate that it is the one that adds the information for that Production field?
2-Do you know any QuickApp or Plugin to be able to connect the GoodWe inverter with the HC3?
Thanks for your knowledge!
Edited by Juanjo
GoodWe integration is on the MarketPlace:
Your EH mode is hybrid one, and it usually comes with grid energy meter installed. Above Integration reads data from that meter, via the inverter, so you do need to add next one.
