Connect Elero Rolmotion
PSi
Just tried to connect Elero blinds with Home Center 3 v.5.110.15
Was able to connect one blind successfully but all others fail: After putting the blinds in learning mode (driving up and down), the pairing aborts with message "Binding procedure timed out or and error occurred! Device not detected, please try again."
The blinds are already connected with a remote, is it possible to learn from this device directly?
Are there any further logs or help available?
I'm waiting for my blinds.
The engines are Rolsolar 868 so that's a different type. (solar energy)
As far as i know you have to disconnect power and power again by each blind you want set in learning mode.
If it works, i don't know.
That's what i've been reading in the Elero manual.
  • Thanks, already had them in learning mode (driving up and down) but it did not work.
    "Luckily" the HC3 crashed today and I had to restore an older backup. After that, the pairing with the remaining blinds was possible and is now working as expected.
    Currently struggling with scene programming logic:
    - when temp is too high, the blinds should close half way if they are are not yet completely closed (should not open when kids are already sleeping)
