How to add a zigbee device?
Hi - I am trying to add my curtain controllers but am having trouble with the adding process with zigbee.
Is there a reference document for adding these devices?
I have tried with and without the installation code method but the page indicates the MAC address is invalid.
Perhaps does anyone have screen shots of adding a zigbee device for reference?
Thanks,
Anth
No, but there is a large open source database and also there is a specific topic here to log/share your experience with other users:
I suggest you try to find your device here, because often caveats and reset procedures are mentioned and they are rather device-specific:
For example: "Livolo TI0001-curtain-switch" has this important remark "can only read status, control does not work yet"
Often they mention a specific pairing process (or reset procedure)
Weird. I do not have devices with "installation code" so cannot test that. MAC might be case sensitive, use dashes, colons or no separator at all between de pairs of hex digits.
I don't have that kind of the device. I did add light bulbs, sensor and switches and it is pretty much "add" then wait, it is very uneventful at the moment. I mean, I don't think there is any user accessible log for example.
I read your question correctly and I told it to my elder brother because they have knowledge about zigbee device
 and I have shared it with my friends. As soon as I get the best answer, I will tell you here
