MarcF1 0
I'm trying to get the Shelly QA working with children. I have 2 Shelly2.5 of which one is configured as a roller and one as two relays. I have also a shellyI4 (a module with 4 digital inputs)
The 2.5 respond to curl Http requests. the I4 (a new model from shelly) does not, most probably because the shelly documnettation is not yet adapted
All 3 work fine on the shelly app and are visible on my IP scanner
The other forum QA's shellyroller and shellyswitch work also. So what is my problem :
I have a Fibaro Yubii because I have a set of NICE 433 Mhz roller controllers and another set of Philips Hue lights
The Yubii has a limit of 10 QA's and 20 scenes.
Because of the scenes I need to use the AIO QA, and because of strange behavior of the Hue plugin I use Children of Hue QA.
And I need a lot of scenes because my wife insists on buttons to control things.
I bought the shelly set because first of all fibaro has no I4 equivalent , second because I need 3 RGBW dimmers, 3 + 4 + 2 digital inputs in different places, and 2+3+2+2 digital outputs and 3 additional rollers , totals 14 devices.
Therefore the cost difference between shelly and fibaro starts adding up. (the I4 cost 16 €, the fibaro RGBW dimmers with 4 inputs costs 55€, rollers are 25 to 48...., Fibaro smart inserts need additional electronics to interface with 220VAC)
so unless I get the QA children working, I'll run out of either money or QA's.
I set the IP and the user/password as they should be , and here below is what the QA says now :
[31.05.2022] [11:28:13] [DEBUG] [QUICKAPP371]: QA Shelly - version:0.9 (QA toolbox 0.18)
[31.05.2022] [11:28:13] [DEBUG] [QUICKAPP371]: DeviceId..:371
[31.05.2022] [11:28:13] [DEBUG] [QUICKAPP371]: Type......:com.fibaro.deviceController
[31.05.2022] [11:28:13] [DEBUG] [QUICKAPP371]: Interfaces:["quickApp"]
[31.05.2022] [11:28:13] [DEBUG] [QUICKAPP371]: Room......:219
[31.05.2022] [11:28:13] [DEBUG] [QUICKAPP371]: Visible...:true
[31.05.2022] [11:28:13] [DEBUG] [QUICKAPP371]: Created...:Sun May 29 10:27:29 2022
[31.05.2022] [11:28:13] [DEBUG] [QUICKAPP371]: Modified..:Sun May 29 18:45:32 2022
[31.05.2022] [11:28:13] [DEBUG] [QUICKAPP371]: Setup: Event manager (0.2)
[31.05.2022] [11:28:13] [DEBUG] [QUICKAPP371]: Setup: Child device manager (0.3)
[31.05.2022] [11:28:14] [ERROR] [QUICKAPP371]: QuickApp crashed
[31.05.2022] [11:28:14] [ERROR] [QUICKAPP371]: Unknown error occurred: no static 'createChild' in class 'QuickApp'
but in edit, I can only find 1 occurence of "createChild", in a commented line of the children module header .
Edited by MarcF10 answers to this question
