Hello !
I try to remove a device Zigbee.
This device does not work anymore.
I have the window
/monthly_2022_06/image.png.ab4d4bf8521c831b41d0bcab51724c39.png" />
but if the device does not answer anymore ???
somebody have an idea ?
thanks a lot !
6 answers to this question
Use manually "force to remove" as follow
Go to devices
Press trash icon
Select Force remove
That's all...
    But I don't have this button "Force remove"
    I have had the same problem.
    Tried to delite and forse remove. it still came back.
    I had to remove the hue app, download again, and let it find the remaining bulbs.
    which firmware du you have ?
    I have the 5.111.48 (beta)
    I have the same problem, unable to remove a zigbee device, I do not have the force remove.
    Is there a solution ?
    Thanks,
    Fly
    Edited by Fly
    Answering to myself, I did a reset of the Zigbee and it worked.
