Sprinklers set Mode or Delay when Rains
Hello everyone!
I just setup a sprinkler system with 2 x 24v solenoid electrovalve and a Fibaro double smart module.
Everything works fine but I need to find a way to delay (24h) or disable sprinkler schedule if it rains. I couldn't find a z-wave soil moisture, so I am trying to use a a Flood Sensor and LUA to do the following:
- if the rain is detected then delay 24h or disable sprinkler schedule (set mode manual/disable or something like that) -> delay 24h -> enable sprinklers schedule (set mode auto).
I have experience with LUA, but I couldn't find a way to turn sprinkler schedule off/auto/manual/etc. I didn't find any documentation on that matter.
Is that something that can be done?
Thank you in advance!
HC2 or HC3 ?
Hi Fuser99,
I have this solution in place using a zWave RGB sensor and humidity sensor.
You might need to use Google translate to translate from Dutch to your preferred language. I have it working on HC3.
regards, Jeroen
    1 hour ago, domin12 said:
    HC2 or HC3 ?
    HC3
    57 minutes ago, JeroenL said:
    Hi Fuser99,
    regards, Jeroen
    I will take a look, thanks.
