amatt 5
I purchased some downlights that work with Hue. I added them to hue and ensured they work. then I added them to fibaro using the plugin with no issues. I set the color to what I want in the app (in this case I want bright white). I run a scene to figure out the value, brightness and saturation. I then put it in a VD as a saved color. once I press the saved color in fibaro the light changes to an off blue color instead of bright white. I can get the light back to a bright white by going to the hue app and adjusting the color so I know its not the light itself. Does anyone know if Hue changed a setting that does not allow the light to change to the correct color? in the app they have 2 different selections for colors and White not sure if this makes a difference on fibaro now.
HC2
latest OS
@T.Konopka
