Temperature- and Energy Panels in HC3/HC3L missing vs HC2/HCL
Hello
I've switched from HC2/HCL to HC3/HC3L.
One of the best features with HC2/HCL, are the Temperature- and Energy Panels where you can quickly compare temperatures and energy consumption for different devices. I've used this a lot.
Now with HC3/HC3L i couldn't find anything similar. I know in General > Main you can export Data from temperature and energy in a CSV file. But that is not at all, the same quick compare possibility.
Does anybody know a possibility have the similar panels in HC3/HC3L?
4 answers to this question
There is an Energy Panel on the HC3. But that is not what you are looking for?
    Yeah, so far I didn't like the energy panel in hc3
    If you don’t like it, build your own with export to InfluxDB and reports with Grafana.
    The energy and temperature panel in hc2 was very useful. It is a pity that it is not present in hc3. I hope fibaro will add it in the next firmware release.
