HC3 with KNX integration
leffr
Hi all,
I've a combination of FIBARO HC3 with ZWAVE devices. Also I've a small KNX installation,
Homey has an plugin that can work with KNX by IP gateway (tested and works great).
Is there something available on HC3 ?
 Hi @leffr,
I think on this forum there were some sollution that used Node-RED.
However, I think by using wireshark you could capture these command and use them in Quickapp.
