AWU 0
Hi
I'd like to open/close the danalockv3 id541 using two triggers.
Holding the light switch (the danalock status changes each time the key id553 is held down) or the alarm output (the ldanalock status changes depending on the alarmoutput id430 status on/off on=unsecure off=secured).
In addition, the alarm output state should be synchronized with the lock state, because I can open the lock manually for example.
How to modify the lua code below to add a second trigger to it (alarm out) and synchronize lock state?
conditions = { {
id = 553,
isTrigger = true,
operator = "==",
property = "centralSceneEvent",
type = "device",
value = {
keyAttribute = "HeldDown",
keyId = 1
id = 430,
isTrigger = true,
operator = "!=",
property = "state",
type = "device",
value = {}
operator = "any"
local deviceValue1 = fibaro.get(541, "value")
if deviceValue1 == true then
fibaro.call(541, 'unsecure')
else
fibaro.call(541, 'secure')
