Ettrig 4
Having an issue where associations doesn't work at all.. ?
Trying to get a Fibaro Motion sensor trigger a Dimmer2. See image below how my association setup looks.
Notes
Using a scene I can get it to work (but I want to use association instead to not rely on the hub)
I did set my HC3 up with Z-wave 3.0 - can this be the problem?
(I note that the Motion Sensor seems added as s0 device.. I couldn't get it to register as S2, but the same goes for all my Dimmer2s (they also registered as security S0))
Before I reset the entire thing and re-do the entire setup I figured I'd throw this question out and see if anyone can have any idea why it's not working..
9 answers to this question
