Landroid Worx robot lawnmower
I would like to purchase a Worx model M700+ robotic lawnmower. You can operate this robot via an app on your smartphone.
Are there people here on the forum who have an integration of this type of robotic lawnmower in their HC3?
4 answers to this question
Hi Sjekke,
I have my Landroid integrated via HomeAssistant. With the Fibaro integration in HASS you can make it work. E.g. make a “Dummy” QuickApp in Fibaro and link it to Landroid in HASS.
I have done this for my curtains like this, not yet for Landroid.
Not an easy solution though.
jeroen
    8 minutes ago, JeroenL said:
    Hi Sjekke,
    jeroen
    Ok thx @JeroenL I will take a look into this.
    Sjekke
    Hey, I;m new to Fibaro, but I have Homeassistant working for me for about 3 years now.
    I have bunch of lights (Tuya and Ikea-via ZHA), curtains (Ewelink), Landroid, Fronius Inverter, Xiaomi purifiers and humidifiers...
    I'm trying to move as much as possible to Fibaro.
    Can you share your solution for curtains?
    I found the sollution for Tuya using Node Red (which I also have), but this was for HC2 VD and not for HC3/HCL3 QA, so I did Node Red part but stuck on QA...:(
    I am using 2 solutions that could inspire you:
    Option 1:
    First, make a (dummy) QuickApp, and then add a switch (in my case a valve) to and link it to the QuickApp.  You need to do like this, as the QuickApps do not show up in HASS.
    You do not need to put any code inside the QuickApp, as if you have linked Fibaro to HASS a new entity will pop-up.
    The entity in HASS can then be picked up by Node-Red for instance.
    /monthly_2022_08/image.png.60ab07646eeb314a952240b08d6bd56e.png" />
    Option 2:
    - For my Harrison curtains (RFX module via domoticz). Basically making http call to open / close
    I created a QuickApp with Blinds without positioning. Copy / paste below code and adopt to your needs.
    Do not forget to create 2 buttons for Open & Close. (see below code) .
    Hope it gets you going ....
