copy state of Hue Lamp, and set another to that exact state.
Hi, It's been a while since I made a topic here on the forum. Everything works smoothly as it should.
That's why I haven't touched my HC3 or made scenes for it for quite a while, and so not sure how to do the next thing.
All my lights are Phillips Hue, i only have one quickapp turning some lamps off with a motion sensor.
The rest is all controlled by a i-casa wall controller. This controller works with touch link. So "outside" of the homecenter.
This works perfect for me, since i can set the status of all lamps, and long press a wall button and it will remember the state of them all.
I have ordered a LED strip with zigbee controller. This one comes in today. But i just found out that touchlink won't work with this thing at all.
So I can't control this LED strip with the i-casa touchlink in-wall controller.
I can send it back and buy a Hue strip three times the price.
Or I can ask for your help :)
This LED strip will register as a Hue integration in the HC3 via the Hue hub. Just like the rest of the lamps. (or at least i hope so)
What I want to achieve:
When "kitchen lamp" turns on, the LED strip copies the status. So on or off AND the color state.
Below is the status output of the lamp i would like the led strip status to follow. (when turning on)
Quote
[27.07.2022] [09:20:16] [DEBUG] [QA_HUE_MAIN_139]: [HG] QA:188 Change in QA Woonkamer-Keuken
[27.07.2022] [09:20:16] [DEBUG] [QA_HUE_MAIN_139]: QA:188 any_on: false -> true
[27.07.2022] [09:20:16] [DEBUG] [QA_HUE_MAIN_139]: QA:188 Last Update: 27.07.2022 09:20:16
[27.07.2022] [09:20:16] [DEBUG] [QA_HUE_LIGHT_188]: [L] Setting label value to lblState 2 - Partially On
[27.07.2022] [09:20:16] [DEBUG] [QA_HUE_LIGHT_188]: [L] Setting value to sldBrightness 32
[27.07.2022] [09:20:16] [DEBUG] [QA_HUE_LIGHT_188]: [L] Setting value to sldHue 78
[27.07.2022] [09:20:16] [DEBUG] [QA_HUE_LIGHT_188]: [L] Setting value to sldSaturation 76
[27.07.2022] [09:20:16] [DEBUG] [QA_HUE_LIGHT_188]: [L] Setting value to sldCt 100
[27.07.2022] [09:20:16] [DEBUG] [QA_HUE_LIGHT_188]: [L] Setting label value to lblLastUpdate 27.07.2022 09:20:16[
27.07.2022] [09:20:16] [DEBUG] [QA_HUE_LIGHT_188]: [L] updateInfo:
[27.07.2022] [09:20:16] [DEBUG] [QA_HUE_LIGHT_188]: Off 2.5W
Can someone help me with that?
Edited by ppeterr
    Update
    I bought a new rgbww controller. This one has the touchlink function.
    So, if you need all the functions like an original Hue lamp has, i'd suggest getting this one.
