talofer99 1
Currently testing a wall mounted switch, with 4 relay and buttons.
The device has a light sensor as well.
On none secure controllers we will get an "end point" of sensor, for example this is how it looks on the Fibaro Lite
/monthly_2022_08/1.jpg.176f57edaf57acfe62852e77c450df34.jpg" />And looking on the unsolicited update frame that is been sent the data is ok and the interface gets updated.
Now on the new Fibaro Home Center 3 Lite, with the Z-wave 3.0 engine in S2 , this is how the interface looks at the end of the join process
Unfortunately I do not have access to the Keys on this fibaro (If you know how to gain them let me know),
but when I tested all the frames that are available for this class it all worked and response well.
Any ideas, suggestions, need for more info will be highly appreciated.
27 answers to this question
