Light sensor not showing on Home Center 3 Light with the Z-Wave 3.0 engine
Currently testing a wall mounted switch, with 4 relay and buttons.
The device has a light sensor as well.
On none secure controllers we will get an "end point" of sensor, for example this is how it looks on the Fibaro Lite
/monthly_2022_08/1.jpg.176f57edaf57acfe62852e77c450df34.jpg" />
And looking on the unsolicited update frame that is been sent the data is ok and the interface gets updated.
Now on the new Fibaro Home Center 3 Lite, with the  Z-wave 3.0 engine in S2 , this is how the interface looks at the end of the join process
Unfortunately I do not have access to the Keys on this fibaro (If you know how to gain them let me know),
but when I tested all the frames that are available for this class it all worked and response well.
Any ideas, suggestions, need for more info will be highly appreciated.
    @m.roszakthank you very much for the information.
    I will look into the % vs lux in the documentation and adjust the code.
    This product is not yet in the market.
    Again thank you, and I will report back if I worked it out.
    @m.roszakI finally got to test this out  - we were busy with other parts of the project.
    I check the setting and indeed they were incorrect and instead of the value being 0x04 (0x01 on Bit 2) it was 0x01.
    I got this value from this table
    Now I adjusted the code and tried to join the fibaro and still I do not see the sensor.
    I check the output of each of the Class command and as far as I can tell they are fine.
    This is the supported Sensors
    This the fixed supported sensor scale
    And this is the sensor report
    Is there something I'm still setting incorrectly ?
    If not, can I send you a log from the Fibaro again to see why I do not see the Sensor ?
    Again thank you for all the help. its highly appreciated
    Tal
    Put logs here again, I will check :)
    @m.roszakthank you very much for the help :)
    Attached is the log, I also first upgraded the device to the latest version
    @m.roszakhi,
    Did you get to test he log?
    Any suggestions why its till now showing up ?
    Thanks in advance,
    Tal
    @m.roszaksorry for the late late reply, I for some reason did not notice the response.
    This will be tested, thank you very much!!!!
    Great, let me know how it went :)
