Martin_N 154
Hi all,
First I will state that I have HC3 on FW version 5.110.
I was making a QuickApp to read a Shelly3EM (3 phase meter).
What I came across the most was that values in kW must be entered into the energopanel once an hour.
As a result of the experiments, I reached almost MWh consumption within a few days.
Unfortunately,... I can "build on my head", but I am not able to reset this data via the standard way via "Panel settings".
Does anyone have a way to get rid of this data.
The picture will show my frustration.
I am using powerSensor to read the current values from the meter to get internal consumption graphs.
However, to introduce it into the Energo panel, it is necessary to use another tap, the EnergyMeter.
For example, the given PowerMeter cannot be selected in the QA definition (perhaps as a child of the type determination in the code).
According to the API hierarchy, PowerSensor is:
>com.fibaro.device/com.fibaro.sensor/com.fibaro.multilevelSensor/com.fibaro.powerSensor.
Whereas according to the API hierarchy there are energyMeter, powerMeter, ...:
>com.fibaro.device/com.fibaro.sensor/com.fibaro.multilevelSensor/com.fibaro.meter/com.fibaro.electricMeter
>com.fibaro.device/com.fibaro.sensor/com.fibaro.multilevelSensor/com.fibaro.meter/com.fibaro.powerMeter
com.fibaro.device/com.fibaro.sensor/com.fibaro.multilevelSensor/com.fibaro.meter/com.fibaro.energyMeter
That is, in another thread of the hierarchy.
11 answers to this question
