Temperature charts in fibaro HC3
Hello guys,
I would like to ask you for these questions:
1) It is in HC3 any place where can i see temperature graphs in one place? ( not i detail of device) - like HC2 display
2) what is mean tab in Climate -> Charts . This tab is not active.
Many thanks for your feedback
  • Like 3
15 answers to this question
I want this too
Some time ago, I contacted with Fibaro support and thay told, that Charts Tab is not yet prepared, so we can only assume, that it will present some charts (like in HC2)
    Anybody from #FIBARO like @K.Drozynskican you share with use any time estimation? HC3 was released more than one year ago and a lot of functions is not there .... Many thanks
    I have found a temperature chart on the device itself.
    Edited by silvinnio
    That we know, and this is the place mentioned in the first post.
    But if you have multiple rooms/thermostats, this is real pain to dig it all out from device properties.
    Would be nice to have some place to see it easier and be able to compare.
    • Like 4
    Bump! When will we get proper temperature charts that can be accessed via app?
    HC3 is not a cheap device so I'm disappointed that much cheaper devices like Shelly have this functionality built in as a standard but in HC3 it's still not available... 😕
    There is a temperature chart
    Ahhhh,
    @petrmikes question was about temperature panel (see one on HC2):
    where you can choose rooms and compare temperatures for selected time, e.g. one week and even export historical data. I do not see that on HC3.
    I guess this is still something that will be added in the future? (see the picture from @petrmikes first post). There is a "Chart" option, but is still disabled.
    Good evening, at least it marks something for you, since I updated the esmart implants that I have with probes they show me 0, excluded and incorporated again and it remains the same, I will not update again because every time I do it I have problems, With all the money that their products cost and it seems that they are developing 5 year old children, I am very angry with the company, hc2 did not cause any problems, because now they are all problems (I am speaking in my case and I am sure that in many of my colleagues ) fibaro...start doing things right please.
    Where do you see this chart on the HC3 or is this something which has to be switched on?
     Under a device "General" Tab that show temperature :D Like this: (it takes some time to load sometimes, so give it a few sec)
    In the adcanced tab it have to enable the save events to database too btw :) (edit)
    Edited by Brors94
    This is the device specific one.
    I'm looking for the chart which suppost to be in the climate panel.
    The problem is that the temperature chart under the device is not accessible for a user (so not the admin).
    Ah, That isnt available yet.
    And sadly not for year :( Hope it will come soon
    @m.roszak got any info here? :D
    Awaiting for system solution, I made and published QuickApp with charts for many types of sensors, and also binary- and multilevel- switches (dimmers roller-shutters).
    So all the graphs are available now also for mobile apps.
    Details at the MarketPlace:
    • Like 4
    Looks great Albert 👍
