Hi there,
I need to connect to AWS MQTT server with tls 1.2 and need to put 3 certificate files, but MQTT always return error code "1".
Here is my code:
My questions are:
  1. AWS wants me to use 3 keys to connect MQTT, basically I should use contents of AmazonRootCA1.pem, private.pem.key and certificate.pem.crt key files, but in tls.options I can see only clientCertificate and certificateAuthority, that made me confused.
  2. When I connect to MQTT with mqtts, I got only error code "1". If code 1 meads " incorrect protocol version", what is the version  of TLS version in QuickAPP Lua?
Is any one have same issue?
10 hours ago, xrdandy said:
My questions are:
afaik tls options does not support keyFile (private.pem.key), so you can't use it like that.
    Hi @tinman ,
    Thanks for your reply!!
    If I can't append private key content, how do I connect to AWS MQTT using tls?
    sorry can't help you with this, maybe FIBARO @m.roszak has an idea
    Thank you so much. I'll find out if there is any other way.
    • 2 years later...
    In my case, everything works fine, with both a local and remote broker using port 1883. However, when I try to connect to a remote broker with a username and password, using TLS or SSL, port 8883 (no certificate required), I can connect to the broker, but the remote broker disconnects me with "Return Code" 5.
    Have you solved your problem? How did it go?
    I've configured the TLS option as described in this and other posts, but it's still the same. I don't know what I'm doing wrong.
    Some guidance would be appreciated.
    Regards.
