@m.roszak
what about to create special procedure for adding devices where any other processes in HC3 will be stopped as a option (ie. stop all QA, NICE/Elero, Zigbee etc)
Unfortunately it won't affect the process of Z-Wave inclusion in any way ;/
19 hours ago, fingusio said:
Today added to clear HC3 (5.110.15 firmware) new Danalock V3 (newest firmware 0.20.2) without any problems :)
If you have a small system, and Danalock is included as the very first device, then maybe it will work, but i can assure you, you will have some problems with it later. I am not saying this based only on my own system, but i have installed several systems, and in 80 percent of them the reporting is bugged. Fibaro not updating the lock states properly, and sometimes even a single LOCK/UNLOCK command can not work.
You have definitelly some chances to have it work correctly, but the chance that it will not work is very high.
To maximize the chance to work it properly, user needs to include Danalock as the first device in the system, and to try to not extend the system too much.
These advices are coming from several installatons, where we experienced the same behaviour all the time.
Edited by Neo Andersson
