z-wave
MrDTS
Hi
HC3 z-wave range is much worse than on HC2, must get an amplifier!
it not reach all places in the house, HC2 does not have this problem although and it is not z-wave plus. !
MrDTS
7 answers to this question
  • Hi
    what do you mean by mesh ? I have learned 2 Fibaro wall plugs where one of them is z-wave plus to the new HC3 and test at the far end of the house there is a problem for HC3 to reach, I chose normal z-wave during the installation as z-wave+ was a Beta?
    most z-wave products I have are without + and it has worked well with HC2 even at the far end of the house.
    the advertisement for HC3 is that it has a longer range compared to HC2 ?
    MrDTS
    Z-wave devices hop from one to another. That is why I ask. If your HC2 had a good mesh of devices, your compare two different setups.
  • Hi
    little other thing, when you add device like now a qubino Flush Shutter, 2 different things are created one with a roller blind and one with a box both have a yellow triangle in the web interface, know that in HC2 I have a lot of those that are hidden in device, thought to try to get it better in new HC3.
    why are a lot of things created that you don't use, and what are these things, can you simply delete them.
    Sorry for bad English
    MrDTS
