Need help with LUA script
I'm writing an Quick App for controlling device using UDP protocol. It's seems to be working, but I have some additional questions.
1. I'm using @tinman QA lib for aes128. When I decrypt response from device I received json formated string with additionals spaces at the end:
{"t":"dev","cid":"111111","bc":"000000000000000000000000000000","brand":"gree","catalog":"gree","mac":"111111","mid":"10001","model":"gree","name":"12312312312","series":"gree","vender":"1","ver":"V1.2.1","lock":0}
OR
{"t":"bindok","mac":"111111","key":"12312312312","r":200}
And here is the problem, that if the spaces are at the end, I cannot do json.decode to get exactly value, any solution?
2. Can't understand why result return in function return nil value. When I debug it it have value, but how to return this value for other function?
Edited by Deivydas
You can trim the string with:
    Ok, the problem was that I cannot use json.decode because that I was using AES library wrong way.
    I made changes from code below:
    To this code:
    After that - json.decode(response) is working
    Edited by Deivydas
    Post updated
    Thank you for replying the correct code so people can learn from it.
    And good to hear your integration works now.
