How can I get a visual indicator of result of a scene execution
RohitNz
Using HC3, I have a manual scene to initialise variables and hardware etc.  What's a good way to get feedback on its result - whether it succeeded or failed?  Checking the Debug Log would be a hassle.  In HC2 it wasn't a problem as the debug info was right there without having to select tag and type.
Is succes/failure is the only notification you want you can send a push message.
