Switch status isn't updated in HC3 from device
Ilya12
I have FIBARO Switches FGS212 and FGS222 added to my new HC3 (ver. 5.130.45). When I change the switch state from HC3, the presentation icon updates accordingly and the relevant scene is triggered. But, when I change the  state of the switch using the wall switch, the icon does not update and the relevant scene isn't triggered. The same process with the same switches in HC2 works fine. The switches are configured with default configuration without any changes and their firmware is up do date.
I tested also FIBARO Door / Window Sensor 2 FGDW on HC3 and its state is updated from the sensor fine.
What could be a problem?
P.S. I see that hidden root device icon is updated by manual switch. So, it's probably something in associations. I tried to change them, but it didn't solve the problem
Edited by Ilya12
